dlavineway
Aug 01, 2019Aspirant
ReadyNAS Ultra 4 - The array is still in degraded mode
Hello just added two new 4 TB drive to my Ultra4; first drive loaded and sync correctly however after installing, test and sync the 2nd I'm now in Unprotected mode with the following messge: "RAID s...
- Aug 02, 2019
dlavineway wrote:
I've tried posting the mdstat.log contents multiple time unfortunatly the post keeps disappearing, trying it as an attachment
Likely just caught in the spam filter.
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md4 : active raid5 sda5[0] sdb5[1] 976750784 blocks super 1.2 level 5, 64k chunk, algorithm 2 [2/2] [UU] md3 : active raid5 sda4[4] sdc4[3] sdd4[2] sdb4[5] 5860511616 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU] md2 : active raid5 sdd3[7] sdb3[5] sdc3[4] 2916119040 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [_UUU] md1 : active raid1 sda2[6] sdb2[5] sdc2[4] sdd2[7] 524276 blocks super 1.2 [4/4] [UUUU] md0 : active raid1 sda1[6] sdb1[5] sdc1[4] sdd1[7] 4193268 blocks super 1.2 [4/4] [UUUU] unused devices: <none>
It looks like the problem is with md2 (and that you started off with a 4x1 TB array).
You could try
- removing the disk
- power down the NAS
- disconnect from the power main for a few minutes (maybe 15)
- reboot the NAS
- reinsert the disk.
Part of the rationale here is to clear out any bios state associated with the disk. Sometime the NAS drivers will declare a SATA bay down, and this should make sure it's up again.
dlavineway
Aug 02, 2019Aspirant
Aug 02, 2019Guru - Experienced User
You could try
- removing the disk
- reboot the NAS
- SandsharkAug 03, 2019Sensei
It doesn't look like a dead bay issue, because all the other partitions of Drive 1 (sda) are included in their appropriate RAID groups.
I think you are going to find a bad sector on the drive. But why it wouldn't just re-allocate it and go on is a mystery.
If it still doesn't sync after you've done all StephenB has advised, I can give you SSH command for it to re-try adding the partition to the RAID. But it's probably unlikely that would be any more successful.
- dlavinewayAug 03, 2019Aspirant
StephenB, your solution work; thank you very much
- StephenBAug 03, 2019Guru - Experienced User
It didn't seem that likely to me either. But in the first post he said the drive was identified in web ui as dead - and it wasn't clear as to why. So I suggested the longer procedure.
