Max_1968
Oct 05, 2015Aspirant
ReadyNAS Ultra 4 dead
Hi, my ReadyNAS Ultra 4 which i use as a backup for my primary NAS was showing increasing SMART errors on disk 4 since some weeks... As i was about to leave for vacation, it was "only" a backup s...
JennC
Oct 06, 2015NETGEAR Employee Retired
Hello Max_1968,
If you haven't removed the disks yet, please download RAIDar 6.0 and install. This will give you an option to download the logs.
Max_1968
Oct 07, 2015Aspirant
Thanks both,
JennC - I have downloaded the logs before i posted here, basically SMART logs for all disks except #4 were fine, and my volume was dead due to double disk failure. I didnt find anything about what happened to #2, but didnt look in detail
StephenB - I followed your proposal, shut down the NAS, took out all disks, numbered them and run them through Seatools. Results as follows:
- Disk #1 - SMART Test - PASS
- Disk #1 - Short Test - PASS
- Disk #2 - Did neither show up in BIOS nor (obviously) in Seatools
- Disk #3 - SMART Test - PASS
- Disk #3 - Short Test - PASS
- Disk #4 - SMART Test - PASS (this surprised me as the Ultra reported it as failed due too to many SMART errors)
- Disk #4 - Long Test - FAIL right at the start
I then did a "full repair" with Seatools on disk #4, followed by another long test on it - This time result was PASS
So it seems now I have the following situation:
- Disk #1 OK
- Disk #2 FAIL
- DIsk #3 OK
- Disk #4 seems OK from a PC perspective, but might either fail right away in the ReadyNAS or again after a short period of time, not tried yet in NAS after repair
(BTW, these are Seagate ST3000DM001 drives about 2.5 years old - I never liked them, but I got the Ultra with them at a very reasonable price and thought for a backup system they are OK...)
My plan now is to clone disk #4 on the PC to the one replacement disk i already have (same type), hopefully get the Ultra and the volume up again, and then replace all disks one by one with 4 TB WD red drives starting with disk #2 to regain redundancy asap. I'd also like to figure out what happened to disk #2, but that has no importance now...
Does that sound like a good plan, any other recommendations ?
Thx,
Max
