IseWise
Sep 28, 2014Aspirant
ReadyNAS Ultra 4 is slowing down my entire network LAN & WAN
Ive owned a ReadyNAS Ultra 4+ for several years now, with little to no problems, however I'm now having a very strange issue.
Every time my NAS is connected to the network, the entire network begins to crawl. And I do mean the entire network, both LAN and WAN. Page loads will slow down and even fail to load, accessing my mapped drives slows down, even wifi devices will slow down.
I am positive it's the NAS causing the slow down because I can unplug the 2 cables and the network returns to optimal performance.
My network:
Motorola Surfboard SB6141
Netgear R7000
Trendnet TEG-S80g siwtch <--- NAS is connected to switch with 2 Cat5e cables.
NAS is on the latest firmware, both network interfaces have static ip set inside frontview.
I tried trading the Trendnet switch for a Linksys SE2500 and that didn't work. I have purchased at the time of this writing a bunch of cat6 cables from Monoprice.com to replace every cable I can to see if that will help performance.
I have found a couple other threads that sound similar to the problem I'm experiencing but no answers or solutions:
http://www.readynas.com/forum/viewtopic.php?f=21&t=76765
http://www.readynas.com/forum/viewtopic.php?f=21&t=56182
Please help me out.
My network:
Netgear R7000
Please help me out.
- muggsyAspirant
FiremedicJM wrote: Did not require a complete wipe, Just wiped the OS partition and rebuilt it so it did not wipe data. Tech support can access it if you put it into Tech mode from the boot menu. PM mdgm and I am sure he can help you.
I'm thinking this is what might be causing me massive network issues with my ReadyNAS Pro as well. mdgm, are you able to help me out possibly as well?
OK, my NAS had been hacked...
Similar to this
http://blog.malwaremustdie.org/2014/09/ ... china.html
What able to fix with the help from the comments...
File was being created in /boot/ and /lib/udev/ , called something random...
Pain in my ass.. I thought I had patched my nas to the latest , but missed 4.2.27
