alcester01
Jun 12, 2019Tutor
ReadyNAS Ultra 4 Plus - OS 6.10.1?
Hi All, Short Question: Is OS 6.10.1 able to run on the Ultra 4 Plus? Context: I run two ReadyNAS devices - a RN214 and this Ultra 4 Plus (used as a backup). Both run OS 6 and I have update...
- Jun 12, 2019
Well, OS-6 isn't officially supported on the ultra (as you likely know).
That said, you should be seeing a prompt for 6.10.1. Is the Ultra update setting set to "stable"?
Jun 12, 2019Guru - Experienced User
- alcester01Jun 13, 2019Tutor
Many Thanks! I had the Check Updates setting on Long-Term Support.
