skim32
Dec 02, 2011Tutor
ReadyNAS Ultra 4 Plus Jumbo Frame Issue
I am having trouble with jumbo frames with my ReadyNAS Ultra 4+. My setup is as follows. Both My Computer and ReadyNAS goes to the TRENDNET S80G. The TRENDNET S80G supports JF up to 9k MTU. So I ...
Silversurfer79
Jan 09, 2012Aspirant
I get a similar issue. My Ultra 4 Plus with JF enabled doesn't work, full stop. As I have rebuild my pc with different motherboard and they both do the same thing. I have it disabled on my pc at the moment and that works fine. Something I did notice though is that the MTU is 9000 on the Ultra and my nic defaults to 9014 would this be the issue as the MTUs are difference sizes? The MTU option for my nic is hard coded, but would it be possible in the next firmware up date to once jf is enabled to allow the field to be edited? I think if I could change the MTU to match it may work.
