skim32
Dec 02, 2011Tutor
ReadyNAS Ultra 4 Plus Jumbo Frame Issue
I am having trouble with jumbo frames with my ReadyNAS Ultra 4+. My setup is as follows. Both My Computer and ReadyNAS goes to the TRENDNET S80G. The TRENDNET S80G supports JF up to 9k MTU. So I ...
Jan 15, 2012Guru - Experienced User
You are not reading correctly. The first ping failed with "Request Timed Out", so it gives no information about the MTU. Not sure why that happened.
rccoleman wrote: If I'm reading correctly, he did that first in that screenshot and the correct answer is 9000 (8972 + 28).
Again, the goal is to find the largest buffer size that returns the normal (successful) "reply from IPADDR bytes=xxx time=y ms TTL=zz" response.
