skim32
Dec 02, 2011Tutor
ReadyNAS Ultra 4 Plus Jumbo Frame Issue
I am having trouble with jumbo frames with my ReadyNAS Ultra 4+. My setup is as follows. Both My Computer and ReadyNAS goes to the TRENDNET S80G. The TRENDNET S80G supports JF up to 9k MTU. So I ...
mdgm-ntgr
Jan 15, 2012NETGEAR Employee Retired
Which version of the GS108T do you have Silversurfer79?
To help isolate cause of the issue does a direct-connection (How to Direct Connect to your ReadyNAS work fine?
Have you tried connecting the NAS to multiple different ports on the switch remembering to enable jumbo frames on the port you try?
