skim32
Dec 02, 2011Tutor
ReadyNAS Ultra 4 Plus Jumbo Frame Issue
I am having trouble with jumbo frames with my ReadyNAS Ultra 4+. My setup is as follows. Both My Computer and ReadyNAS goes to the TRENDNET S80G. The TRENDNET S80G supports JF up to 9k MTU. So I ...
Jan 18, 2012Guru - Experienced User
Fail with a timeout or fail with the DF response?
Silversurfer79 wrote: All responses over 1500 all fail and under 1500 work perfectly.
In addition to direct connect, you might also try the ping -f -l xxxx test directly to the switch (taking advantage of its IP address).
Also, is there internet security/firewall software running on the PC?
