Moto
Sep 03, 2015Tutor
Readynas Ultra 4 Plus no valid volume exists #25703630
Help! I had a power failure today, and now I am getting a "no valid volume exists" and cannot access any of the shares on the NAS, although they are listed in Finder on my Mac. However, I cannot acc...
mdgm-ntgr
Sep 03, 2015NETGEAR Employee Retired
Hi Moto,
Support needs you to reply to their email so they can escalate your case.
Moto
Sep 03, 2015Tutor
I have replied, thanks.
- JennCSep 04, 2015NETGEAR Employee Retired
Hello Moto,
Looks like you need data recovery contract. Maybe best to call support for more explanation.
- MotoSep 04, 2015Tutor
The Level 2 tech said that there was some sort of problem mounting the drives, and that they could be manually re-mounted. However, it has been escalated to Level 3 and I have not heard from them yet. Apparently there is a failing drive that the Level 2 guy thought could be replaced and fix the problem . . . fingers crossed. He did say that he didn't think that the data was at risk.
Hi Motto,
Yes it has been escalated from L1 to L2 and L3. I checked your records and found that L3 requries data recovery for the issue you have on the NAS. The L2 tech has not updated you yet, I saw that you ahve already asked for an update. L2 tech who escalated this case is probably not around yet. It seems some thing with the partition is the problem.
