mrlexe
Aug 19, 2015Aspirant
ReadyNas Ultra 4 stuck on booting
Hello, i have a readyNas ultra 4 that is now "stuck" booting. I just formatted all the disks on the unit (2x 2TB WD and 1x 1TB Seagate). After that it starts and it just says "booting" in the displa...
- Aug 19, 2015
Rebooting.
Should now be fixed.
vandermerwe
Aug 19, 2015Master
What happens if you boot the device with no disks?
Can you try to factory default the nas with only one disk in it. Test the disk you use with vendor tools first.
Are you the original owner and if so when did you buy it ?
if you are not the original owner, when and where did you get it?
mrlexe
When i boot the device without any disks it just say ERR: No disks detected. I have tried booting the device with one disk in at a time (diffrent disk every time) same thing happens. I have also tried the disks and found now faults. Memory test performed also with no luck.
