polysemous
Oct 12, 2015Aspirant
ReadyNAS Ultra 4 Volume Dead - but files still there in SSH
I noticed a few days ago that I was unable to access any of my SMB shares on the ReadyNAS. Yesterday I finally had some time to check things out and found that under Volume Settings, Frontview is re...
Oct 13, 2015Guru - Experienced User
polysemous wrote:
I cleared some space from the crashplan directory, restarted the ReadyNAS and everything seems to be working correctly again.
You might not be done with this yet. Have you seen this thread? https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/td-p/985781
Also, I'd strongly recommend moving crashplan's cache to the C volume.
polysemous
Oct 18, 2015Aspirant
Thanks!
