rashoo's avatar
rashoo
ReadyNAS Ultra 6 - stuck on syncing
Hi,   It seems that RAID scrubbing unveiled a disk error. But now my ReadyNAS seems to be stuck at 29% on syncing. The system is configured as a single volume, 6 x 1TB WD1003FBYX drives,  X-RAID2...
  • StephenB's avatar
    Nov 19, 2018
    Do you know what drive has failed?
    Conversion to OS-6 is destructive, so you will need to restore your files from a backup anyway.  If you already have that backup, you could just proceed with the OS-6 conversion.  You can do that with one drive, and then do a factory install when the new drives arrive.
ProSupport for Business
