PETROV
Nov 27, 2015Tutor
Readynas ultra 6 dead motherboard
My Ultra 6 is not booting any more, After turning on the power the blue light goes on, disks start spinning, and i get readynas on the display. But it does not boor or the network lights on t...
Sandshark
Nov 29, 2015Sensei
My first suspect would be the power supply -- specifically the CPU 3.3V. You can use a standard ATX supply mounted externally to determine if it's the power supply, and replacements are available (though not from Netgear). A motherboard going bad is certainly a possibility, and you have already eliminated many others. But the power supply is a known sore spot for early failure.
