PETROV
Nov 27, 2015Tutor
Readynas ultra 6 dead motherboard
My Ultra 6 is not booting any more, After turning on the power the blue light goes on, disks start spinning, and i get readynas on the display. But it does not boor or the network lights on t...
PETROV
Nov 30, 2015Tutor
The power supply is good,
I have tried a new ATX supply as sugested, same result, you can power on and off the device, disk starts spinning, Readynas shows in the display then nothing
is there an other board i can try
Sandshark
Dec 01, 2015Sensei
The Ultra6 does have a VGA header on the motherboard (at least, it's labeled as such and has the right number of pins), though I have never connected to it and do not recall seeing confirmation here tht it is of standard configuration. But Netgear tends to be pretty consistent, so I suspect that it is (as it is on the 6-bay Pro models). With a proper cable, you could look for BIOS messages during boot-up to try and diagnose further.
- PeetvvDec 05, 2015Aspirant
Pluged a VGA connector , but it as well remains black no signal, so really the board is broken, i am sorry to say but it nust be possible to get e new board, they must have been mass produced
so the question remains where to find a replacement board where have they been manufactured
- PETROVDec 08, 2015Tutor
I have measure al the voltages on the board and they seem normal, are there simulr problems with this board is the an other way to try to repace the firmware, I have tried to boot from USB
