DanielEnochsson
Nov 01, 2022Tutor
Readynas Ultra 6 frontview with firmware 4.x shows an empty frame without the configuration menues.
I have a Readynas Ultra 6 with 6 x 4 TB which has ended up in a pretty useless state and I need help to be able to use it again. It is basically factory reset, sharing the default file structu...
- Nov 03, 2022
Welcome to the Community!
If the NAS is on Tech Support mode, can you send me a PM regarding its port number? so we can try to get access to it. Also, kindly provide the photo of the label with the model number.
Many thanks
DanielEnochsson
Nov 02, 2022Tutor
Okay, I just realized that the "leds" in the lower right corner actually allows me to monitor the state of disks and fans etc. However this NAS is on its way to my blind friend and I'm not too sure he will be able to check those leds with his screen reader software, so we still need to recover the GUI
DanielEnochsson
Nov 02, 2022Tutor
...but I would not be able to pinpoint which drive to replace if the drive led changes to red...
Btw, another thing I tried in order to recover the NAS was to boot without disks and to boot with just one other disk...
Boot without disks results in message "ERR: No disks detected!" on the built-in display and no webserver.
Boot with one different disk results in the same empty frontview frame with no way forward.
- SandsharkNov 02, 2022Sensei
Does the model or serial number in RAIDar look messed up? If so, and maybe even if not, your problem sounds like a corrupted VPD (vendor product data) file. Only Netgear can repair that. The mods ( @Marc_V and @JeraldM ) sometimes repair the VPDs remotely, so that is perhaps an option.
- DanielEnochssonNov 02, 2022Tutor
Really good input, thank you. Yes, the model name is garbled in the output of the Raidar app.
Problem is that I have attempted to put the unit in "Remote support" mode from the boot menu, but it didn't work... (I read somewhere that this could give access to the unit over ssh). Most of the boot menu is not-working, as far as I can tell so it's no longer possible to do factory reset etc. So if bringing the NAS up with "Remote support" actived is a precondition for fixing the unit then that's my next problem.
Actually, I decided to try again to choose Tech Support from the boot menue and this time actually worked. Not sure why it didn't work before, but now the NAS is booted in Tech Support mode and it will stay powered on in this mode for now. Hopefully Marc_V or JeraldM will show mercy on my system. I have taken a photo of the label underneath the unit, as a preparation and I'm ready to share the port number with them.
