Zecaf
Apr 12, 2016Guide
ReadyNAS Ultra 6 Plus - Volume C on life support
So, I'm having a bad week I guess... My setup : ReadyNAS Ultra 6 Plus [X-RAID2] 6x3Tb Firmware: RAIDiator 4.2.28 Memory: 1024 MB [6-6-6-18 DDR2] Volume C: Online, X-RAID2, 6 disks, 78% of 13 T...
- Apr 17, 2016
Quick follow up : I did manage to backup / save everything (in unprotected mode) and I jumped on the occasion to upgrade to OS 6. I'll open a new thread for some specific questions about it.
mdgm-ntgr
Apr 12, 2016NETGEAR Employee Retired
Do you have a backup?
If not, it sounds like you should could consider purchasing a data recovery contract so that support can remotely look into this.
For future reference when you have multiple disks failing, but only a single-redundant volume it is not a good idea to replace a failing disk. The resulting resync which puts heavy stress on all disks can finish another disk off leading to the NAS ending up in life support mode as has happened in your case.
Backing up the data or maybe cloning the failing disks e.g. using dd_rescue would have been more appropriate.
Personally with 6x3TB disks I would have chosen to use X-RAID2 dual-redundancy. In fact I'm using this with my Ultra 6 with 6x3TB disks and my RN516 with 6x6TB disks.
Zecaf
Apr 13, 2016Guide
Weird, I did answer you but can't see my post on the page... oO (ok, I didn't see it asked my login again, NOT my week, really. ;) )
Well, short version:
- work related documents / important stuff (photos / music) are safe in the cloud too. I knew that 10 Tb account was a good idea. ;)
- Medias / software archives / old work archives are the problem here. I can survive but the time invested in the media curation would be lost and yep, I'd be sad. But I can only blame Western Digital here and my own stupidity.
I'll try the support to see If we can do some magic to save some stuff. Then I guess it's the "perfect timing" to upgrade to OS 6. I just ordered 2 other NAS drives from Seagate this time...
Now, let's find that support link... :x
Edit: I only find a number to call... no online / chat / whatever support?? oO (that website + windows 7 installation advisor REALLY don't push me to call :P)
- ZecafApr 13, 2016Guide
Wow, I just booted the NAS to check the serial : it's back online and trying to resync from scratch.
I just turned it off again, I'll remove the new disk to stop the resync and manually backup what I can before the 2 others sick drives finaly decides to die on me...
(and I found the online support btw... https://my.netgear.com/mynetgear/portal/myOnlineTicket.aspx)
- ZecafApr 17, 2016Guide
- mdgm-ntgrApr 17, 2016NETGEAR Employee Retired
Glad to hear that you were able to backup your data. Thanks for letting us know.
