Shah079012
Mar 09, 2017Aspirant
ReadyNAS Ultra 6 Plus
Good morning, can I please get a techincal contact to remotely login to my NAS (ReadyNAS Ultra 6) login code 52944 and latest screenshot below. Netgear ReadyNAS Ultra 6, Firmware 4.2.3.0 I have had...
Ki_Adi_Mundi
Mar 09, 2017NETGEAR Employee Retired
Did a quick check, didn't find root full:
nas-EA-CE-D0:~# df -h Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 455M 3.4G 12% / tmpfs 16K 0 16K 0% /USB /dev/c/c 9.1T 8.2T 923G 91% /c nas-EA-CE-D0:~# df -i Filesystem Inodes IUsed IFree IUse% Mounted on /dev/md0 65536 12936 52600 20% / tmpfs 126593 1 126592 1% /USB /dev/c/c 152168448 495900 151672548 1% /c
- Shah079012Mar 09, 2017Aspirant
many thanks for taking a quick look, this seemed to fix the issue last time, i have tried os re-install already this morning a couple of times to no effect. I gave my login access previous and permission but im not exactly sure what he did for me. From all of the forums i have read on the net and on here I cant find any solid answers on how to remedy this other than "Replaced the SMB config file with the default one and now the share is accessible over SMB". that seemed to do the trick last time. though i cant find any instructions on how to do this. Are there any available?
many thanks for your assistance
i can provide the log file printouts if that would help also
- Ki_Adi_MundiMar 09, 2017NETGEAR Employee Retired
I had remote access, so logs are not necessary.
Seems some settings lost in /etc/default/services, may try re-set something, can you enable CIFS in Services->Standard File Protocols by admin UI ?
