niallryan
May 29, 2023Guide
ReadyNas Ultra 6 stuck on READYNAS logo
Hi all, hope everyone is well. I was working on my readynas Ultra 6 Pro the other night by scheduling maintenance - Defrag, Balance and Scrub. I has set up the schedule for the 28th of every month a...
May 31, 2023Guru - Experienced User
You can easily downgrade back to 6.10.6 if you want to. No need to worry about that now.
Testing the disks makes sense as a next step - either putting them in another OS 6 NAS if you have one, or connecting them to a PC and using vendor tools.
As Sandshark says, we haven't ruled out the power supply as the problem.
niallryan
May 31, 2023Guide
Hi guys,
I put the 6 x 4TB HDD's in the same order into the other NAS of the exact same spec and I get the same result.
Then READYNAS Logo and nothing else.
I do have another NAS (ReadyNAS Ultra 6 Pro) and I put the disks into that and turned it on. The READY NAS Logo appears and it goes through the motions where the 6 drives appear on the left of the display and the Booting.... and under that is the % booted. It gets to about 30-39% and then powers off and restarts again.
Now to be fair if this has anything to do with this particular NAS is that it has not been turned on for some time - 6 months at least. When it was turned on with these drives in it , it was powering like revs and going off and then powering on again and then off and so on for a while before it eventually kicked on with the readynas logo.
Regards
N
- niallryanMay 31, 2023Guide
Hi there,
While I am waiting for response on last 2 posts I said I would put the HDD's from the working NAS and put them into the NAS that I had my movies.
Powered it on and all working with these drives inserted. AND version 6.10.8 running as stated the other day.
So this tells me that the issue is on the drives themselves as not able to boot ? Possible corruption somewhere ?
Currently these drives with my movies on them are on the known to be working NAS which would have OS 6.10.6
So with all the information to hand what do I need to do to resolve the HDD issue? NO drives are reporting to be faulty thank god but more of a booting issue I hope/think.
Kindest Regards
N
- StephenBMay 31, 2023Guru - Experienced User
I think the next step is to test the drives - best done in a PC using vendor tools. Seatools for Seagate, and WD's dashboard software for Western Digital. I suggest running the full non-destructive test.
Another option would be to try and boot the system in tech support mode - that would require some linux skills. I don't recall - is that something you've done before?
- niallryanJun 01, 2023Guide
Hi again guys,
I suffer from brain fog so forgive me as I just looked up how to put the NAS into Tech Support Mode and will do so shortly. If any of you can have a look I would be greatly appreciative. Not having a great week with lots going pear shaped on me.
Many thanks
N
Hi guys,
Feeling pretty grim now. Tried to enter menu mode as instructed but it does not happen. It just continues with ReadyNAS logo. I noticed that the internet does not even light up but that probably down to the priority of the booting up and would come on if the NAS continued.
Either way I am at a loss now and fairly worried about my data (approx 10TB).
Is there any way to check the disk other than with a PC - is there Mac M2 software ?
Regards
N
- StephenBJun 01, 2023Guru - Experienced User
Overall, I am guessing that you have two issues - I am thinking that
- the power supply in the ultra 6 failed, perhaps due to the extended scrub
- Likely a disk is failing (which was why the scrub took so long).
The power supply in the Ultra 6 can be replaced.
There might be some diags available that could run on the mac. I don't own a mac, and it's not something I've researched,
Unforunately, it is at risk. RAID isn't enough to keep it safe, you really need a backup plan to do that. Hopefully we can recover it.
One option (likely expensive) is for you to locate data recovery service that can off-load the data on the disks to USB drives for you. That would be the lowest-risk next step.
There might also be a PC shop nearby that could test the drives for you. If you can identify one that is misbehaving, then you could install the other 5 in the Pro 6, which could get you past the startup problem there. After that back up the data.
I'm hesitant to pursue the tech support idea. While booting in tech support mode would let Netgear access the system remotely, it wouldn't let Sandshark or me do that. You'd have to log into the NAS with telnet and run the linux commands yourself. It'd be difficult to provide much guidance here on the commands, and if you were to make a mistake you could make the data unrecoverable.
Hi StephenB
Many thanks for coming back and I was thinking that its at risk.
StephenB wrote:Overall, I am guessing that you have two issues - I am thinking that
I thinking that the power supply is fine as it is currently running as normal with the HDD's I swapped with the issued HDD's. Basically I swapped NAS's between each set of Drives. The NAS which had the drives when Scrubbing is now running normally with other HDD's inserted - no issues.
So basically it must be a disk failing in some way. I can get a Windows laptop - Obviously I have the HDD's labelled 1,2,3,4,5 & 6 - so using a HDD cradle connected to the PC and run the software you suggested to test the drives.
If its only one drive (fingers crossed) that is faulty and as I am running RAID5 on all NAS's I could just replace that drive and rescue data.
The drives in this particular NAS with the issue are IronWolf (I think) so would have to get same as replacement if that's the root we are taken.
All my other NAS drives I have WD Red HDD's.
Also the reason that the PU must be ok is that I have the drives in another NAS and get the same response. The only NAS I got a different response was the Ultra 6 Pro which booted up to the % booting and getting to 39% before shutting down and re-starting. I wonder if I should try that again to see if it boots up now that that NAS has been running for 24 hours as was not used for sometime before that.
Regards
N
The current WD Red drives are all SMR (shingled magnetic recording) - which is not a good technology choice for ReadyNAS. The WD Red Plus disks are good choices.
You can mix and match. Most of my disks are WD Red Plus (though many were branded as WD Red at the time of purchase), but I have mixed in some Ironwolf. I've found them both to be pretty reliable. Currently I compare Ironwolf and WD Red Plus prices, and get whichever is cheapest.
Ok, I must have missed that. Obviously let the scrubbing complete on that NAS.
I don't think that will work. You could try the boot option to skip the file system check - but I am not sure if OS-6 will pay any attention to that boot option (as it doesn't exist on the newer NAS).
FWIW, the OS-6 NAS have a "read-only" boot option instead, which would have allowed for some more experimentation. But not the Ultra and Pro ReadyNAS.
- niallryanJun 02, 2023Guide
Hi StephenB
I was reading back over to see if I read something you said correctly and it made me think....
StephenB wrote:There might also be a PC shop nearby that could test the drives for you. If you can identify one that is misbehaving, then you could install the other 5 in the Pro 6, which could get you past the startup problem there.
Is the following possible or maybe I am reading your above statement slightly extended 🙂
Insert all 6 HDD's in the correct order. Them remove one HDD at a time and boot up. eg Remove HDD 1 from slot 1 and boot up and see if this gets me past the Hanging Logo and if not then re-insert HDD 1 and remove HDD 2 and so on. ?
OR
Is what you mean that in testing each HDD that I find the faulty 1 and insert the remaining 5 and boot = do I insert the remaining 5 in to their original slots ? or insert remaining 5 into slots 1 to 5 ?
Granted I am inclined to go with the former thinking as I presume that all HDD's must be in their original slots for it to work
Regards
N
- StephenBJun 02, 2023Guru - Experienced User
The NAS should assemble them in any order. However, it is easier to troubleshoot problems if you know the original slot order.
I was actually thinking that if you knew for sure which disk was bad, then you could just boot up the NAS w/o it.
Your idea would be safe in a a native OS-6 NAS because you can boot up those NAS read-only. If somehow the NAS did write something with only 5 disks installed, then the data volume would be out-of-sync. Repeating this several times could increase the risk of data loss.
So there would be some risk with your idea. It might turn out to be the only practical option, but it'd be good to expllore other possibilities first.
- niallryanJul 08, 2023Guide
Its been a few weeks but had a lot going on and got back to this issue and managed to get a windows pc and downloaded and installed the software you recommended to test the HDD's (also to note there is a Mac version 🙂 )
Anyways I started with the Seagate software and ran the Long Test (no mention of destructive btw). So the following is the results with this software up to present time.
HDD 1 - Passed
HDD 2 - Passed
HDD 3 - Passed
HDD 4 - Passed
HDD 5 - Currently testing
HDD 6 - Immediately Failed
In case you're wondering how I know this.... lol - I could not unscrew HDD 5 from the cradle (well 1 crew in particular) so jumped to HDD 6 as it takes about 12-14 hours to test a drive.
When I inserted the drive into the caddy and turned it on the software immediately came up with the exclamation mark and when I tried all the various tests it failed after about 5-10 seconds of starting.
I am just wondering - there is a Fix All option in the software - any good to run this with that drive ? or would it destroy the data on it eg (RAID5 system)
Also, If this being the issue (fingers crossed) can I boot up the NAS with just the 5 HDD's in it or should I wait until I get a replacement drive.
Many thanks
N
- SandsharkJul 08, 2023Sensei
You can try booting up with just the 5 drives and see if it comes up with a degraded (non-redundant) volume. It's possible that the one bad drive was affecting the entire SATA subsystem, so it's your only problem. But it's not that likely. There is no "fix all" because there are too many things that can go wrong. StephenB can help you with the commands needed to try and assemble the volume once he gets a look at your logs.
- StephenBJul 08, 2023Guru - Experienced User
My experience with that feature in the past was never good, so I don't use it.
Generally once a drive starts to fail, it rapidly gets worse. So the track sparing in the software doesn't seem to help for long.
You can boot with 5 drives. The array should mount, and should be marked as degraded.
Hi StephenB
Many thenks for coming back to me.
I was thinking the same thing to be honest.
You can boot with 5 drives. The array should mount, and should be marked as degraded.Yes again was thinking the same thing. With the degraded the NAS would still work but slower than normal. Also would I be able to add to the NAS while in degraded mode?
Kindest Regards
N
- niallryanJul 09, 2023Guide
Good morning StephenB Sandshark
I re-inserted HDD5 after it passed the HDD test. Then powered on the NAS without HDD6 inserted and it booted up. Everything was normal as in the NAS was not displaying any issues on its display when I was expecting to see a notice of it saying that the system is degraded. So I went on my laptop and logged into the readynas Home Screen.
When. I logged in there was a message at the top but it wasn't a system degrading message. It was a message saying to remove the necessary drives BECAUSE when I clicked on Volumes icon all the drives are RED and it is saying that the NAS is FULL = zero space available.
I wonder if this has anything to do with the initial process it was doing as I am only 90% sure it was completed before the power was interrupted.
Will the NAS recover to normal when I insert a replacement drive into bay 6 ?
Kindest reagrds
N
- SandsharkJul 09, 2023Sensei
No, it will not self-repair when you replace Drive 6. It does appear the death of drive 6 caused a problem on the SATA bus, but did so during a write. So data on one or more other drives is corrupt or out of sync. Hopefully, you can now download the log .zip and StephenB can use that information to better diagnose the specifics of your issue and help you at least get the volume mounted so as to allow you to get your backup up to date before factory defaulting the NAS with a new drive.
- StephenBJul 09, 2023Guru - Experienced User
The volume is probably out of sync. Download the full log zip file from the logs page.
I can take a look at that for you if you like. Just upload it to cloud storage (Dropbox, google drive, etc), and send me a download link in a PM (private message). Use the envelope link in the upper right of the forum page.
I will be traveling this week, so it might take me a couple days to get to it.
- SandsharkJul 10, 2023Sensei
Please send your PM on the location of the logs to StephenB, not me. I'm really mainly a hardware guy, but I've also run a lot of experiments on ReadyNAS to learn its ins and outs and have seen a ton of messages here in the forum about volume issues. But when it comes to diagnosing and repairing BTRFS and MDADM issues, StephenB has far more experience than I.
The screen shot really doesn't clear things up except to say that there is something more wrong than just a missing drive, as I had already surmised. There are a lot of things that can go wrong and result in that display, thus the need to upload the logs to see which problem yours is.
- niallryanJul 10, 2023Guide
My apologies and I have done so. Many thanks for all the advice and help as always. You and StephenB really show what a community stands for. Many thanks for this and everything else in the past.
I reckon it is going to be a long road ahead and expensive by the sounds of what StephenB has been correlating to me.
StephenB has already told me that the logs indicate that the RAID is in sync and it is more of a file system issue. So hence a long road ahead.
Kindest regards
N
