schwalbenbengel
Nov 20, 2021Aspirant
Readynas Ultra 6 stuck on Updating FW
Hi all, I was trying to reinstall the Firmware 6.10.5 on my ReadynasUltra 6 Plus and now it is stuck in Booting... Updating FW. I tried using the boot menu but that didn't help. OS Reinstall lea...
schwalbenbengel
Nov 26, 2021Aspirant
What does full root partition mean?
The installed drives are more ore less empty?
How can I see how full the root partition is?
I tried for example to install the plex server application.
Nov 26, 2021Guru - Experienced User
The NAS boots from the disks, and there is a small OS partition (also called the root partition) on the drives. That can get full.
One way to check it is to download the log zip file, and look in volume.log Scroll down to this section:
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1.1G 2.7G 30% / tmpfs 1.9G 0 1.9G 0% /dev/shm
/dev/md0 is the OS partition.
Did you download it directly from plex.tv?
- schwalbenbengelNov 26, 2021Aspirant
Looks pretty good I think:
=== df -h ===
/dev/md0 4.0G 1.4G 2.3G 38% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 2.0G 5.7M 2.0G 1% /run
tmpfs 987M 8.7M 978M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/md127 15T 3.6T 11T 25% /VolumeI tried several applications.
"Available Applications" section.
And also directly downloaded it from Plex.tv
- StephenBNov 26, 2021Guru - Experienced User
=== df -h ===
tmpfs 2.0G 0 2.0G 0% /dev/shmYes. FWIW, it is a bit high (typically it is lower than 30%), but not anywhere close to full.
Have you confirmed that the NAS can reach the internet? If you are using a static IP address (configured in the NAS), then you should double-check that you've configured the DNS servers.
