ReadyMark
Dec 20, 2011Tutor
ReadyNAS Ultra 6 Tivo Not Archiving -- KUID problem?
I have had a running battle trying to get consistent archiving from from Tivo (Premier XL) to ReadyNas Ultra 6 plus - for a while it seemed to mostly work but since July it only very rarely works with...
pmyers
Dec 20, 2011Aspirant
ReadyMark,
I'm experiencing the same problems as you. ReadyNas Ultra 4 w/ RAIDiator 4.2.19 which includes readytivo 1.3.7 and readydlna 1.0.22. I have two TiVo's. A Series 3 HD and a TiVo Premier.
Videos from both TiVo's that are KUID show up with logs like the following when the ReadyNas attempts to archive them:
[2011/12/20 22:49:21] tivo_utils.c:249: info: Bones (The Male in the Mail) is no longer KUID (expires 2038-01-19T03:14:00Z). Skipping.
The file is KUID on the TiVo, and the database does not list that program id (I've used prune.txt to wipe the database clean and have verified that the database is empty via manual sqlite3 commands run from a different box on the db file)
One theory is that perhaps it is a TiVo update that broke readytivo here? Maybe in the past the TiVo's would set KUID expiration dates to a specific value (say, 2050) and a TiVo update changed it so that KUID values are now set to 2038. And if readytivo was checking with logic like "If expiration date is > 2049 then this is KUID". But if TiVo changed the KUID date to be earlier, now readytivo no longer views that as KUID.
The logic is in tivo_utils.c... If I could see the source code, perhaps I could find out more. Any chance we can get source here?
