ReadyMark
Dec 20, 2011Tutor
ReadyNAS Ultra 6 Tivo Not Archiving -- KUID problem?
I have had a running battle trying to get consistent archiving from from Tivo (Premier XL) to ReadyNas Ultra 6 plus - for a while it seemed to mostly work but since July it only very rarely works with...
jackohound
Dec 31, 2011Aspirant
Hi denarius,
You can easily retrieve the ReadyTivo logs via the FrontView web interface. On the right hand FrontView menu, choose "Status" and then "Logs". In the upper right corner of the logs window, click on "Download All Logs". This will download a zip which you can unzip locally and will contain various log files, including "readytivo.log". That log will contains the KUID dates as well as the version of ReadyTivo.
