ReadyMark
Dec 20, 2011Tutor
ReadyNAS Ultra 6 Tivo Not Archiving -- KUID problem?
I have had a running battle trying to get consistent archiving from from Tivo (Premier XL) to ReadyNas Ultra 6 plus - for a while it seemed to mostly work but since July it only very rarely works with...
Skywalker
Jan 25, 2012NETGEAR Expert
That could be okay. If you've recorded the same show+episode already in the past, and it's been archived by the ReadyNAS, then it's fine. If the ReadyNAS sees a show/episode on your TiVo marked KUID, it checks to see if it's already been archived. If it's a duplicate, then we see if the recorded time is newer than the last time it was archived. If it a newer recording, and marked KUID again, we assume the last recording was a bad one, and we replace it with the newer one.
We'll make this message go away in cases like this in 4.2.20 as well.
