Nightraider89
Jan 09, 2019Aspirant
ReadyNAS Ultra 6 v.6.9.4 . Shares missing, and Commit failed in WebGUi
Hi there,
Got some issues with my NAS, shares are not available in windows anymore, also not if i type the adress manually.
when i want to make changes in the webui, it says commit failed...
Jan 09, 2019Guru - Experienced User
Nightraider89 wrote:
Lately my root drive (/dev/md0) was 100% full at an instant, did manage to get that back to a 80% full, still much, but i dont know how to get it more down ( there are apps installed such as Unifi Controller (symlinked to /apps), Plex, java, mono and so on.
Basically you put everything you added in /apps, and symlink as needed in the OS partition. If you downloaded the Netgear version of Plex from Plex.tv, it should already be in /apps. As you likely know, /apps is a mount point for /data/.apps, so it is really on the data volume.
Are your shares listed in the NAS web ui? It'd be helpful to know if your issue is corrupted SMB configuation files, or if it is bigger than that.
- Nightraider89Jan 09, 2019AspirantHi!
Thanks for your quick replay :)
In frontview i can see my shares.
Windows cannot.
Zo basicly , pihole and that stuff needs moving to the apps dir. Getting on that Tomorrow :) - Nightraider89Jan 09, 2019Aspirant
Got my /dev/md0/ partition back to 48%. Mono, java, unifi, pihole, clamav all redirected to the /apps directory
after a reboot of the NAS still no signs of my shares in windows. In Frontview they are available
- StephenBJan 10, 2019Guru - Experienced User
Normally it is 20-25% 48% should be safe though.
First thing is to check if smbd is running. If it is, then perhaps create a test share and see if it shows up in Windows.
After that you might take a look at /etc/frontview/samba/Shares.conf (and Shares.conf.admin).
- Nightraider89Jan 10, 2019Aspirant
In Frontview , SMB is Running ( light is green) altough if i want to enable or disable it, it is giving the following error:
Unable to start or modify service
15002030001
and another error
16002050008
Also, adding or deleting a share also gives an error, but when adding it does appear in Frontview after the error.
