Nightraider89
Jan 09, 2019Aspirant
ReadyNAS Ultra 6 v.6.9.4 . Shares missing, and Commit failed in WebGUi
Hi there,
Got some issues with my NAS, shares are not available in windows anymore, also not if i type the adress manually.
when i want to make changes in the webui, it says commit failed...
Jan 09, 2019Guru - Experienced User
Nightraider89 wrote:
Lately my root drive (/dev/md0) was 100% full at an instant, did manage to get that back to a 80% full, still much, but i dont know how to get it more down ( there are apps installed such as Unifi Controller (symlinked to /apps), Plex, java, mono and so on.
Basically you put everything you added in /apps, and symlink as needed in the OS partition. If you downloaded the Netgear version of Plex from Plex.tv, it should already be in /apps. As you likely know, /apps is a mount point for /data/.apps, so it is really on the data volume.
Are your shares listed in the NAS web ui? It'd be helpful to know if your issue is corrupted SMB configuation files, or if it is bigger than that.
Nightraider89
Hi!
Thanks for your quick replay :)
In frontview i can see my shares.
Windows cannot.
Zo basicly , pihole and that stuff needs moving to the apps dir. Getting on that Tomorrow :)
Windows cannot.
