Nightraider89
Jan 09, 2019Aspirant
ReadyNAS Ultra 6 v.6.9.4 . Shares missing, and Commit failed in WebGUi
Hi there,
Got some issues with my NAS, shares are not available in windows anymore, also not if i type the adress manually.
when i want to make changes in the webui, it says commit failed...
Nightraider89
Got my /dev/md0/ partition back to 48%. Mono, java, unifi, pihole, clamav all redirected to the /apps directory
after a reboot of the NAS still no signs of my shares in windows. In Frontview they are available
Jan 10, 2019Guru - Experienced User
Normally it is 20-25% 48% should be safe though.
First thing is to check if smbd is running. If it is, then perhaps create a test share and see if it shows up in Windows.
After that you might take a look at /etc/frontview/samba/Shares.conf (and Shares.conf.admin).
- Nightraider89Jan 10, 2019Aspirant
In Frontview , SMB is Running ( light is green) altough if i want to enable or disable it, it is giving the following error:
Unable to start or modify service
15002030001
and another error
16002050008
Also, adding or deleting a share also gives an error, but when adding it does appear in Frontview after the error.
- StephenBJan 10, 2019Guru - Experienced User
You might want to look in /etc/frontview/samba/Shares.conf, and see if it holds all your shares, or only the one you just added.
Also, look in the full log zip file for the details on the errors.
In the Shares.conf file all my shares are listed, the old aswell as the new ones. nothing weird there (for a noob eye :') )
Shares.conf.admin is empty.
full set of logs downloaded, i will sent you a pm with a link to the logs, maybe you can spot some faults?
