dhih93's avatar
dhih93
Readynas Ultra Offline - Little Help?
Hi guys.
Readynas Ultra 2 on OS6.2.
When i connect via browser i get the device is offline message.
On the unit the piwer light is blinking and the Act light is flickering. No drive lights.
Any ideas?
Dean
  • I see you were running OS6 previously with some addons. Did this start when you installed 6.2?
    Do you have a backup?
    Does raidar see the nas?
    Were you still using jbod as you said in another thread?
    I would power down and test the disks using vendor tools first, although this doesn't sound like a disk problem.
    I think there have been reports of users having problems with OS6.2 on legacy hardware when they have addons.
    I see that your attention was drawn to the implications of using OS6 on legacy hardware. You may be heading for another factory default.
  • Hi vandermerwe,
    Yeah, so a legacy model, tweaked for OS6. Failed after an automatic update. After a month of messing around I saw last night that 6.2.2 was available.
    I upgraded to this an boom, all back to normal! I've tried to log in today and it's back to the old offline message.
    I don't have back up, though in the process of getting a 4TB external for this purpose. All the data was there for the brief time I had it back up and running.
    Raidar does see the NAS and yes just using JBOD.
    Interestingly, I noticed when I went to re-launch the Plex app it gave me a fail message. I uninstalled it and re installed it and launched OK. So I'm starting think there may be a conflict with Plex?!
  • StephenB's avatar
    plex survived my upgrade to 6.2.2 (running on my RN102)
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Do you have SSH enabled?
    If not it would be a good idea to enable this so some troubleshooting can be done if you see the "Device is Offline" error message again.
ProSupport for Business
