Beefcurry
Nov 04, 2006Aspirant
ReadyNAS with Canon ZoomBrowser EX
I would say readyNAS performed quite well, as a photography enthusiast I work with many DSLR cameras such as the Canon 350D, 30D, 1Ds and sometimes Nikon D70. For nearly everything I take i take in RA...
loop_none
May 03, 2009Aspirant
I did it. You have to search for 83 C0 FE 83 F8 01. There is a typo in the advice above. It's C-Zero, not C-Oh.
I used XVI32.exe. It takes 2 minutes, and use the Find feature, paste in 83 C0 FE 83 F8 01. It appears twice. Just click or double-click on 01, and type Zero-Three with your keyboard. Then save the file.
Now I can browse network shares easy enough. But what I like is acquiring images, and for that, I am supposed to use the sub-module 'CameraWindow' software, which is included with ZoomBrowser EX, and called up when clicking 'Acquire & Camera Settings'.
The problem for me is CameraWindow does not see my network shares. This is not a problem with 'read-only', the network shares simply don't appear - even if, the network shares are attached network drive letters. What DLL do I have to edit to fix this problem?
Regards.
Regards.
