takagari
Oct 24, 2014Aspirant
Readynas won't seem to expand
NV+ V2 5.3.11 I had it setup 2TB 3TB 2TB 3TB Don't ask me why.. Number one emailed me with a noticed fault. So I purchased a new 3TB. Replaced the first disk. It took a day and rebuilt. A...
mdgm-ntgr
Oct 24, 2014NETGEAR Employee Retired
The disk in slot 1 is slightly smaller than the other 3TB disks so your volume won't expand further using this disk. A backup and factory default (wipes all data, settings, everything) and restore from backup would resolve this as the NAS would use the smallest 3TB disk when determining the size of the partitions for the layer.
When you say the NAS won't take in any more data, you mean writes to the NAS fail?
