takagari
Oct 24, 2014Aspirant
Readynas won't seem to expand
NV+ V2 5.3.11 I had it setup 2TB 3TB 2TB 3TB Don't ask me why.. Number one emailed me with a noticed fault. So I purchased a new 3TB. Replaced the first disk. It took a day and rebuilt. A...
mdgm-ntgr
Oct 24, 2014NETGEAR Employee Retired
I would suggest backing up your data etc. as I suggested in the post above. Can you backup the data already on the NAS to some place else?
As for seeing what can be done about the disk capacity you would need to hook the disk up to your PC and use the drive vendor's utility (i.e. WD Data Lifeguard Diagnostics for a Western Digital disk) to check.
