hard2name
Apr 07, 2022Aspirant
ReadyNas102 - Volume Root Usage
Version 6.10.7 Only apps on RN102 are iDrive and Resilio sync. I removed iDrive last evening. At beginning of 2022 I noticed my iDrive was not backing up from RN102. I reinstalled it (or tried to...
- Apr 08, 2022
hard2name wrote:
It just looks like all of mine must have more junk than yours (cores/lib/ftp) but the big problem looks like "log." Any thoughts on what I need to do here?
Yes, it's definitely /var/log.
Try going deeper, that would help sort this out:
root@NAS:/var/log# du -h /var/log 0 /var/log/news 112K /var/log/apt 0 /var/log/fsck 436K /var/log/frontview/backup 3.1M /var/log/frontview 0 /var/log/samba/cores/nmbd 0 /var/log/samba/cores/smbd 0 /var/log/samba/cores 752K /var/log/samba 3.2M /var/log/apache2 2.3M /var/log/readynasd 39M /var/log/journal/6c58f1a31323453ea933c21fd1d53cbe 39M /var/log/journal 0 /var/log/clamav 0 /var/log/audit 50M /var/logAnything in /var/log/clamav can be safely deleted, the RN102 no longer has the AV service.
hard2name
Apr 08, 2022Aspirant
Here is what mine shows:
It just looks like all of mine must have more junk than yours (cores/lib/ftp) but the big problem looks like "log." Any thoughts on what I need to do here? I very much appreciate your assistance Stephen B. You are on a ton of these posts and it's great that you help so many people with this stuff, it's extremely generous of you. Thanks again.
Apr 08, 2022Guru - Experienced User
0 /var/log/news
112K /var/log/apt
0 /var/log/fsck
752K /var/log/samba
0 /var/log/clamav
0 /var/log/audit
50M /var/log
- hard2nameApr 08, 2022Aspirant
There was a 1.5G file /var/log/squeezeboxserver, so I just removed that.
I haven't had squeezeboxserver on there for probably five years, maybe 10, so I have no idea what that was doing there. I hope it doesn't reappear. I guess it actually didn't have anything to do with my reinstalling iDrive -- thought the timing is strange. I guess I will put that back on there and see if I can get it working again. In any event, thanks so much for your help. My /var/log is down to 85M now, so I should be all set unless there is something else you think I should do. I had changed my e-mail password so I wasn't even getting alerts about this -- I am so glad I happened to look at the logs. That isn't something I ever do, so I am lucky I caught it before it was too late. Thanks again.
