Krissos
Jul 23, 2016Star
Readynas102 Firmware issues
I have seen this device really slated in reviews saying the firmware was like a beta, that it could not do the most basic functions (e.g. user file permissions, cloud support flakey), was a nightmare...
Hopchen
Jul 23, 2016Prodigy
The RN102 uses the same firmware (same feature set) as any other of the newer NAS models. Of the models I have is a RN102. Works perfectly fine. Now, one has to understand that this is not a powerful NAS and thus depending on your usage you might need a more powerful one.
But as far as firmware goes - it works fine.
Krissos
Jul 23, 2016Star
Thanks for reply, so is that a way of saying it is not fit for purpose?
Here are some of the issues raised that I would like to know if solvded:
Netgear: As a systems administrator, I’ve used and supported your switches and routers for years, but this product is abisimal. I wasted several days’ time and labor troubleshooting the buggy firmware, and attempting to get help from Tech Support. SHAME ON YOU!
Prospective buyer: RUN, don’t walk away from this product and any ReadyNAS product using OS 6, as they are not even ready for beta testing let alone a production environment!
Explanation:
The OS 6 firmware isn’t even ready for beta testing as it is riddled with bugs and features that don’t even work. For instance, you can’t create additional Administrator accounts, so if you want to designate others to manage the system, you all have to share the same Administrator account and password! This is completely contrary to best practice security procedures. Then there’s the problem where you can’t access any file shares from the cloud unless you are logged in as an Administrator. That’s not a typo! A Standard User account won’t see any of the shares, and thus, users can’t access their files. What’s the point of making files available to the cloud if users can’t even have access to them? Given these two MAJOR flaws, the only way you could get this unit to work (and any other ReadyNAS unit that uses OS 6) and allow users to access their files is to let them all share the sole Administrator account. But then you run the risk of inexperienced users inadvertently deleting files, deleting folders, changing global system settings, and even deleting entire volumes and their backups.
I opened a trouble ticket with Netgear and after detailing the problems with the firmware with the tech, and was promised someone would get back to me within 72 hours. After four days of not hearing anything, I called Tech Support again and this time I was told that they acknowledged the nature of my problems and agreed that it was system-wide flaw that would have to be addressed with a new firmware release. The tech wanted to escalate the problem to his engineers, and once again was promised someone would get back to me within 72 hours. After waiting another four days, I called Tech Support back again and informed them I was going to RMA the unit since Netgear was unresponsive to me and this problem.
Since then, Netgear released a new firmware, v6.0.6, and according to its release notes, still hasn’t addressed these major flaws along with numerous others that I haven’t mentioned here due to space constraints.
You’ve been forewarned!
- HopchenJul 23, 2016Prodigy
Hi again,
So, firstly this is a community forum. Most people here are users (like you) that try to help each other out. There is no need to copy/paste from a long email that you send to Netgear (mainly complaining about support).
I don't recall saying that this NAS was not fit for purpose? I use my RN102 to pull some backups from various devices in my house. It has been going without a hickup for 2-3 years since I got it. But, again - depending on your needs, you might need to get a NAS that fits your purpose.
To address your email. Most of it is based around critisism on Netgear support and not actual questions. The two specific questions you have:- Multiple admin accounts. The NAS only has one admin account. That is not an issue. Regular users should definitely not access the NAS with admin accounts. They should have regular user accounts assgined to them.
- "A Standard User account won’t see any of the shares, and thus, users can’t access their files". I assume you are refering to ReadyCLOUD here? That should work fine now. One admin user can share content to regular users via the cloud. What you describe sounds like a permissions issue?
Anyhow, you are referencing a firmware that was released 3-4 years ago (6.0.6). The latest firmware is 6.5.1.
We will be happy answer some questions you have, but please ask those specific questions.
- What are your needs?
- How many users?
- What is the usage typically?
- Any features you are particularly interested in?
- etc.
Thanks- KrissosJul 23, 2016Star
So, firstly to ASSuME the message was from me was wrong, I have had a dozen Infrant/Netgear NV+ units, they always served me well albeit they have their quirks as any kit does.
However, there are posts like the above all over the web from different people, I saw that some are old and hence my question, have all the bugs been fixed now?
No you did not say it was not fit for purpose and goodness knows there seem to be a lot of purposes in the blurb,one site said it could support 5 users in a household streaming video, yet it can't trancode Plex.
Then you then say "Now, one has to understand that this is not a powerful NAS and thus depending on your usage you might need a more powerful one." so I figured it maybe it can't do all those things the blurb says very well. The general consensus elsewhere seems to be that it is underpowered and limited in memory which is not expandanle.
Although not my post, I am concerned about users having to have Admin accounts so you seem to suggest this issue has been fixed which is good.
You also suggest that the other issue the guy raised has been sorted so that is good too.
Well I am getting rid on the NV+ units because they use up so much power, drive capacities have increased and so a 2 drive unit should suffice.
I wonder if this unit can map a PC share and play a video from that share?
it is not so much an issue of how many users, but rather when I want to do something I want to do several things at once
There is no automation, I may just upload 50gb or 100gb of files or download them, I am not interested in this cloud stuff, too many security issue. I do not like Wizards, I prefer an old fashioned menu where I can config things.
I saw some videos on YouTube that show some super user friendly interface, not keen on that, I am no AppleBoy, I want to see under the hood. I might config it as an Itunes server if it can cope with that.
I do not like to install software on my PC's for devices, I prefer native \\192.168.1.x and mapping a share.
I would like to know if this unit will really benefit from high performance drives or is the network interface a bottleneck?
Can this NAS cope with file serving to a PC configured as a Plex Server?
Hi Krissos,
Thanks for clarifying a bit :) Let me try and answer your questions based on my own experience with it.
"I wonder if this unit can map a PC share and play a video from that share?"
Yes it can - but just streaming and not transcoding. In the past, I've used it quite a bit to stream all our 1080p movies to the TV. I used a Raspberry Pi with Kodi that streamed from the NAS. Streaming is not really an issue.
"it is not so much an issue of how many users, but rather when I want to do something I want to do several things at once"
Heavy multi-tasking it cannot no. But I have used it for things like streaming to the TV and working on files on the NAS at the same time. But again very light multitasking.
"I saw some videos on YouTube that show some super user friendly interface, not keen on that, I am no AppleBoy, I want to see under the hood. I might config it as an Itunes server if it can cope with that."
The userinterface is of course a polished interface where you can do most of what you need. However, I am in the same boat as you. I like the "under the hood" operations. The NAS is a Linux Debian install essentially and you have full access to the CLI if you want (through SSH). I configured most of my NAS via the CLI. But I use Linux a lot in my household, so it wanted a NAS where I can do that. Netgear does not support you doing this, in the sense that they may deny you support if you have "messed around" too much in the "backend". But that is fine. On the forums here there are plenty of people who use the CLI and will happily give some advise.
"I would like to know if this unit will really benefit from high performance drives or is the network interface a bottleneck?"
The real bottleneck here is the CPU. It is a small single core ARM processor. Buying high performance drives will gain you very little.
"Can this NAS cope with file serving to a PC configured as a Plex Server?"
I don't even think that you can install Plex from the apps menu anymore. I think they removed that. I just looked at my apps selection and I cannot find the Plex app on the RN102. You could of cause install it yourself. The NAS is not strong enough for any transcoding at all. However, streaming through Plex - possibly might be OK. Sorry, I don't use Plex so I never tried it on this unit.
I will agree with the "general consensus" that it is a bit on low side, in the powerhouse department. But I also think that it is always important to research what you buy. The hardware specs have always been visible in the datasheet.For example, on any small netbook laptop I can technicall install any game or any application that I want. But I don't - I buy the laptop with right hardware specs for my needs.
Are you planning on buying one or do you have one already? It is for home use or business?
Cheers
