Rob_Halliday
Apr 15, 2017Aspirant
ReadyNAS312 Resyncing at every start-up
Hi All.... So this week is turning in to a bit of a ReadyNAS saga. The problem right now is that I have two new 4Gb hard drives in a ReadyNAS312, with the unit factory reset to get them to format...
Apr 15, 2017Guru - Experienced User
Rob_Halliday wrote:
And is indicating this is an 8 hours process even though there is no data on the drives.
RAID resync operates below the file system, so every block in the volume is synced (even free space) - so the time is normal.
The NAS will resync if the system is improperly shutdown - but it shouldn't be doing that if you shut it down through the web ui or the power schedule.
Did you check the SMART statistics on the drives? You do this on the performance tab. click on the icon next to each drive (e.g. the round ball), and you will see reallocated sectors, pending sectors, ATA errors, etc. If you aren't sure if they are normal, post them here.
Rob_Halliday
Hiya,
There are no errors showing on either of the drives.
I'd have said the system had only ever been shut down properly since the factory reset, but I had it in my head that that involved pressing and holding the power button until the NAS shut down. Checking the manual again, it says that proper shutdown from the front panel is to double press the power button, so maybe press-and-hold does trigger an improper shutdown?
So I guess we'll wait six hours then have another go.
However:
- any thoughts on this 'Error Reporter: An error has occurred' message that now appears every time I browse to the admin page?
- should the unit have had to spend six hours syncing the drives immediately after a factory reset (when one would have assumed it would just have formatted both drives and marked them as synced)?
Thanks,
Rob.
- StephenBApr 15, 2017Guru - Experienced User
Now that we've gotten past the resync...
I don't know what's provoking this. You might try PMing mdgm (using the messages link in the upper right), and ask if he'd be willing to analyze your logs.
- jak0lantashApr 15, 2017Mentor
Did you install any app?
Can you try clearing the cache of your browser?
- Rob_HallidayApr 15, 2017Aspirant
Yes, 4Tb not Gb.
No apps installed.
Clearing the cache in the browser (Safari on a Mac): error persists. However, using Google Chrome doesn't give the error. This error is new since upgrading to ReadyNAS OS 6.6.1, so maybe it's a feature of that ReadyNAS OS release?
Am confused about long-press vs double-press to power down. I've always used long-press back to the days of the ReadyNAS Duo, without seeing this constant re-syncing. Has this functionality of the power key changed somewhere along the way?
I understand the difference between formatting and sync. My question is, though, if you factory reset the ReadyNAS, which effectively wipes the data from both drives, should it not understand that the same operation has happened to both drives without having to first sync them? Doesn't matter in the context of this, but am just curious.
Thanks,
Rob.
