goi
May 25, 2017Guide
ReadyNAS6 Pro failed to boot with "could not properly extract" after Upgrade from 6.6.1 to 6.7.3
Hi,
urgent call:
- Just updated from 6.6.1 to 6.7.3, during this upgrade a boot message came up with "ERR: could not properly extract".
I cannot reach the system by SSH to look what ha...
- May 25, 2017
Solved by mdgm:
- copied the root (md0) partition
- a rebuild of the md0 partition was made
- recopied the data back to md0
- and initiated an os extract on next reboot again
not to forget:
MANY THANKS TO MDGM! You saved my day.
mdgm-ntgr
May 25, 2017NETGEAR Employee Retired
It's one thing to know how the credentials (which are not hard to find on the web), it's quite another to know what to do after you login. I've sent you a PM.
goi
May 25, 2017Guide
Solved by mdgm:
not to forget:
