nswafford
Aug 30, 2016Aspirant
Recommended backup method.
I could really use some pointers for backing up some important data. I've spent numerous hours over the last couple of weeks and have tried several backup configurations only to find that it didn't w...
nswafford
Aug 31, 2016Aspirant
I'm using the backup that came with Server 2012 Essentials.
mdgm-ntgr
Sep 05, 2016NETGEAR Employee Retired
The inbuilt backup software?
Which firmware are you running on the ReadyNAS?
- nswaffordSep 06, 2016Aspirant
I'm using Microsoft Backup that came with server 2012.
Latest Firmware. I've been experiencing some strange things with the NAS though. Sometimes when I click on the Cloud tab I get a different set of options and there are only 3-4 of them. One of them being Remote. I believe it's a much older version of the firmware.
It looks like this. If I refresh my browser it will usually revert back to the newer screen. Not sure if it has anything to do with the problems I have been having, but I do think it's strange.
- JennCSep 06, 2016NETGEAR Employee Retired
Hello nswafford,
Maybe you should try clearing your browser cache.
