milks
Aug 04, 2013Tutor
Remot rsync setup: Error connecting to ...
Hi I have a Raspberry Pi with a mounted USB HDD which I would like to act as a remote backup for my ReadyNas Ultra. I have an rsync daemon running on the RPi but no matter what I try I cannot get...
JohnnyB11
Aug 15, 2013Aspirant
milks wrote: rsync -avh test [email protected]:/mnt/usb_hdd
I do get an error 'Connection refused (111) rsync error: error in socket IO (code 10) at clientserver.c(122)' if I use a double colon in the command (not sure what this is doing differently): rsync -avh *.sh [email protected]::mnt/usb_hdd
The double colon means to connect via rsync deamon. A single colon will use a remote shell. Thus, there seems to be no rsyncd running on your RPi. Or, there it listens to the wrong ip address or wrong port or the port is blocked by a firewall. You could use "netstat -tlpen" on the RPi to check whether there is a rsyncd listening on the local address 0.0.0.0:873.
