Retired_Member
Oct 18, 2011Remote access to frontview unusably slow - what can be done?
Hi, not sure if this is the right place for this question, but here goes: How can I improve or even influence the speed of accessing a remote NAS from across the Atlantic? I'm trying to set up a b...
Oct 18, 2011Guru - Experienced User
I have set up / forwarded an alternate https port, and I frequently log in with frontview remotely (including when I am overseas). Generally I have not had any issues, though of course the speeds are slower. I also use fios. So it is a bit surprising that you aren't able to.
Even if you have fast connections at both locations, you are still subject to cross-congestion / slowdowns on the full wide area connection path (across the Atlantic for instance). So your speeds will vary, and connections can time out.
Therefore, for file transfers I would suggest FTP, (and also suggest enabling upload resume on the NAS). Then if a connection drops, the transfer can automatically resume, so it is much more robust than http. (Backup with FTP may not be so easy, since incremental FTP is more-or-less deprecated).
If you have VNC or remote desktop installed, you can also connect to a PC at home base, and use its browser to connect to frontview. I don't know if that would be any faster though (and wouldn't recommend trying to do file transfers that way).
