Retired_Member
Oct 18, 2011Remote access to frontview unusably slow - what can be done?
Hi, not sure if this is the right place for this question, but here goes: How can I improve or even influence the speed of accessing a remote NAS from across the Atlantic? I'm trying to set up a b...
Jjnsgy
Dec 29, 2011Aspirant
kc1 wrote:
mdgm wrote: Frontview is not designed for access from a remote site.
Really? I access the admin functions on my NVX all the time. Just can't seem to get a fast enough connection to the remote NV+No
mdgm wrote: Do you have a PC you can remotely login to and use to access Frontview? What's that?
StephenB wrote: I also use fios. All I'm trying to do with frontview is setup an rsync backup to pull data from the local NAS from a remote NAS...which I thought was the whole idea with these boxes?
StephenB wrote: for file transfers I would suggest FTP What can be done to deal with or improve this, so that it at least works? Surely I can't be the only one with a ReadyNAS on both sides of the Atlantic?
StephenB wrote: Even if you have fast connections at both locations, you are still subject to cross-congestion / slowdowns on the full wide area connection path
kc1 - can you provide more details about how you are able to remotely access Frontview and your admin functions?
