Anonymous
Oct 18, 2011Remote access to frontview unusably slow - what can be done?
Hi, not sure if this is the right place for this question, but here goes: How can I improve or even influence the speed of accessing a remote NAS from across the Atlantic? I'm trying to set up a b...
Anonymous
Dec 30, 2011
StephenB wrote: Ok. I think I would try switching from 443 to a different port number (forwarding the new port number in the US router, and adding it as port 2 in the https NAS configuration). For instance, if you used 50443 as the second port, your browser URL would change to https://mydomain.com:50443/admin/
Hi - Verizon's Actiontec MI424WR router allows for alternative http & https ports, which we set up, but made no difference, unfortunately.
