Retired_Member
Oct 18, 2011Remote access to frontview unusably slow - what can be done?
Hi, not sure if this is the right place for this question, but here goes: How can I improve or even influence the speed of accessing a remote NAS from across the Atlantic? I'm trying to set up a b...
Dec 30, 2011Guru - Experienced User
I suggest you start a new thread on your problem, since having two conversations on this thread will be very confusing.
Jjnsgy wrote: Can I trouble you for more specific instructions for a noob? A little about the port forwarding, but the front view access remotely.
Also, I am just setting up my nas and do have port 80 forwarded (to test - understand security risks and will change later on) and also have port 443 forwarded to the NAS. When I log on remotely (with IP address or with my domain name assigned by TZO - option for linksys router) with HTTP or HTTPS, I connect (I think) but get a blank page and it appears to be stuck in a loop of trying to load something from the server (IE reads "connecting") - but nothing comes up. Suggestions?
