Anonymous
Oct 18, 2011Remote access to frontview unusably slow - what can be done?
Hi, not sure if this is the right place for this question, but here goes: How can I improve or even influence the speed of accessing a remote NAS from across the Atlantic? I'm trying to set up a b...
Anonymous
Dec 30, 2011
StephenB wrote:
kc1 wrote: ...If you have the remote management on the actiontec configured for port 80 and port 443, then you are giving the router conflicting instructions - telling it to forward ports 80 and 443 to the NAS, and at the same time telling it to allow remote management of the router itself on the same ports. I am not sure what it will do in that case.
I suggest you configure the NAS to use a completely different second port for https, and forward that in the actiontec (matching my approach, which I know works).
Mine in the US is set to port 5151. Just times out, as described, hile it's loading the frontview page. As a test I tried pointing it to the extplorer add-on, but the same thing happens - starts to load the page, and then times out. I've tried various other port permutations, but it doesn't seem to make any difference. The tracerts show it timing out on the last 2 hops at the verizon end.
