Retired_Member
Oct 18, 2011Remote access to frontview unusably slow - what can be done?
Hi, not sure if this is the right place for this question, but here goes: How can I improve or even influence the speed of accessing a remote NAS from across the Atlantic? I'm trying to set up a b...
Jjnsgy
Dec 30, 2011Aspirant
StephenB wrote: I suggest you start a new thread on your problem, since having two conversations on this thread will be very confusing.
Jjnsgy wrote: Can I trouble you for more specific instructions for a noob? A little about the port forwarding, but the front view access remotely.
Also, I am just setting up my nas and do have port 80 forwarded (to test - understand security risks and will change later on) and also have port 443 forwarded to the NAS. When I log on remotely (with IP address or with my domain name assigned by TZO - option for linksys router) with HTTP or HTTPS, I connect (I think) but get a blank page and it appears to be stuck in a loop of trying to load something from the server (IE reads "connecting") - but nothing comes up. Suggestions?
My apologies and will do so. Thanks for your help. But will have solved the problem and will post the solution here:
My primary router is a Linksys e4200. Unfortunately, it is located in a closet and the house is well shielded so the room where the NAS is has poor wireless access - but is wired on a LAN. I plugged my old WRK54G (all DHCP turned off, acting as a switch and WAP) and connected the NAS to this (in addition to stereo receiver and Sony Bluray player) - all are connected to the ethernet ports. Somehow, the wrk54g was blocking access. When I connected the NAS directly (omitting the WRK54G), everything worked like a charm!
Thanks for the assistance!
