nappa
May 13, 2013Aspirant
Remote shutdown on OS 6?
Is there a way to do a remote shutdown on OS 6?
I found this for older versions: viewtopic.php?p=94750
but nothing for OS 6.
- ciarpameTutor
Thank you very much chirpa, I was able to find the Chrome way by myself but I was missing the right CURL syntax.
My Readynas is a NV+ V2 so I suppose is OS5. Anyway xml syntax is almost identical. This is my working CURL command (xml captured with chrome dev tools):curl -s -v -u admin:password -k "https://IP_OF_NAS/dbbroker" -H "Content-Type: application/x-www-form-urlencoded;" -H "X-Requested-With: XMLHttpRequest" --data "<?xml version=\"1.0\" encoding=\"UTF-8\"?> <xs:nml xmlns:xs=\"http://www.netgear.com/protocol/transaction/NMLSchema-0.9\" xmlns=\"urn:netgear:nas:readynasd\" src=\"dpv_1389313459000\" dst=\"nas\"> <xs:transaction id=\"njl_id_725\"> <xs:custom id=\"njl_id_724\" name=\"Halt\" resource-id=\"Shutdown\" resource-type=\"System\"> <Shutdown halt=\"true\" fsck=\"false\"/> </xs:custom> </xs:transaction> </xs:nml>"
For the 6.4.0 OS:
curl -u admin: password -k "https://IP_OF_NAS/dbbroker" -H "Content-Type: application/x-www-form-urlencoded;" -H "X-Requested-With: XMLHttpRequest" --data "<?xml version=\"1.0\" encoding=\"UTF-8\"?><xs:nml xmlns:xs=\"http://www.netgear.com/protocol/transaction/NMLSchema-0.9\" xmlns=\"urn:netgear:nas:readynasd\" src=\"dpv_1445852944000\" dst=\"nas\"><xs:transaction id=\"njl_id_2269\"><xs:custom id=\"njl_id_2268\" name=\"Halt\" resource-id=\"Shutdown\" resource-type=\"System\"><Shutdown halt=\"true\" fsck=\"false\"/></xs:custom></xs:transaction></xs:nml>"
- SandsharkSensei
How about directly from PowerShell instead of having to install cURL? How would one convert all of those cURL options into a PowerShell Invoke-RestMethod CmdLet?
- nappaAspirantWorks perfectly. Thank you!
Great tip about the network inspector in Chrome, too. Very convenient. And here I was looking for the call in javascript.
Thanks again! - chirpaLuminaryEasy way to sniff XML for ReadyNAS via Google Chrome browser...
Open Dashboard, then in Chrome choose Tools>Developer Tools. Click on the Network tab in that Inspector. It will show you all network calls. Run the command you want, and find the related dbbroker call for it. You can then 'Copy to curl' in the right-click menu to get a working curl call for it. - chirpaLuminary
They switched to XML.
This should work:curl -u admin:password -k "https://IP_OF_NAS/dbbroker" -H "Content-Type: application/x-www-form-urlencoded;" -H "X-Requested-With: XMLHttpRequest" --data "<?xml version=\"1.0\" encoding=\"UTF-8\"?> <xs:nml xmlns:xs=\"http://www.netgear.com/protocol/transaction/NMLSchema-0.9\" xmlns=\"urn:netgear:nas:readynasd\" src=\"dpv_1368497621000\" dst=\"nas\"> <xs:transaction id=\"njl_id_1278\"> <xs:custom id=\"njl_id_1277\" name=\"Halt\" resource-id=\"Shutdown\" resource-type=\"System\"> <Shutdown halt=\"true\" fsck=\"false\"/> </xs:custom> </xs:transaction> </xs:nml>"
