davidr1
Nov 08, 2017Luminary
Replacement NAS (downunder)
I need to replace a failed Pro ( V+12 voltage in enclosure Internal is out of spec. (10.72 V). ) despite replacing with two differe power packs (which run hot). All backups to it now fail All back...
Nov 13, 2017Guru - Experienced User
davidr1 wrote:
Can anybody suggest why I should choose one over another?
There's not much performance difference.
The RN314 will give you a couple of "Business NAS" features - for instance ReadyDR and file search.
- davidr1Nov 14, 2017Luminary
Thanks StephenB.
Re the Business features - File search I thought would be useful but frankly I've never used it.
The 314 I was hoping to secure has, regrettably, gone out of stock. :-)
