jtriplej
Jun 29, 2012Follower
Reset Password - I give up!
I have a ReadyNAS Duo V 1. I have had it for about a year and a half and have never had to do anything with the settings after initial setup. Now I do want to change some settings and for the life o...
mdgm-ntgr
Jun 29, 2012NETGEAR Employee Retired
If an OS/firmware re-install doesn't fix the problem it's likely some configuration files have been corrupted and you should contact tech support (http://www.ReadyNAS.com/support) for assistance.
