aVe2000
Jan 03, 2015Aspirant
resize swap on readynas 104
hello readynas people, does anyone could help me in resizing swap size on my device readynas 104? Its an arm based linux device. I know how to connect to my device via putty and i am familiar with ...
chirpa
Jan 03, 2015Luminary
I wouldn't recommend resizing it. The system hard codes those values, expanding later could cause issues.
You can use swapon command to add more swap space via flat file on the data partition. Or try 'apt-get install swapd', it runs a daemon that dynamically adds swap as needed, then removes it later.
