Miraculix1
Aug 22, 2017Tutor
Resource busy
Hi, I just updated my RN516 with FW 6.8.0. I use my NAS with OSX Sierra, connected with SMB, and I do have problems deleting files useing finder. When I try to delete a file with OSX Finder I...
- Oct 11, 2017
I did not find a solution for this problem, today I updated to 6.9.0 RC1.
Now the smb access works fine.
This behaviour is not mentioned in the update notice, but it solved my problem.
Miraculix1
Aug 22, 2017Tutor
Hi Evan,
thanks for the quick response.
Sierra 10.12.6 is installed.
The log is on its way
Miraculix
evan2
Aug 23, 2017NETGEAR Expert
I checked there is btrfs warning on you NAS, I am not sure if it is root cause, but the problem need to fix.
Aug 20 13:29:42 Vierings-Daten kernel: BTRFS warning (device md127): qgroup 12508 reserved space underflow, have: 0, to free: 4096 Aug 20 13:29:42 Vierings-Daten kernel: ------------[ cut here ]------------ Aug 20 13:29:42 Vierings-Daten kernel: WARNING: CPU: 1 PID: 3348 at fs/btrfs/qgroup.c:2480 btrfs_qgroup_free_refroot+0x140/0x170() Aug 20 13:29:42 Vierings-Daten kernel: Modules linked in: sx8635(O) vpd(PO) Aug 20 13:29:42 Vierings-Daten kernel: CPU: 1 PID: 3348 Comm: btrfs-transacti Tainted: P W O 4.4.79.x86_64.1 #1 Aug 20 13:29:42 Vierings-Daten kernel: Hardware name: NETGEAR ReadyNAS 516/To be filled by O.E.M., BIOS 4.6.5 10/11/2013 Aug 20 13:29:42 Vierings-Daten kernel: 0000000000000000 ffff8800a8aabc58 ffffffff883d9498 0000000000000000 Aug 20 13:29:42 Vierings-Daten kernel: ffffffff88cfc618 ffff8800a8aabc90 ffffffff8806e41c ffff8800a8b03808 Aug 20 13:29:42 Vierings-Daten kernel: ffff8800a8b03780 0000000000001000 ffff880119efc000 0000000000000000 Aug 20 13:29:42 Vierings-Daten kernel: Call Trace: Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff883d9498>] dump_stack+0x4d/0x65 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff8806e41c>] warn_slowpath_common+0x7c/0xb0 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff8806e505>] warn_slowpath_null+0x15/0x20 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff8835e7c0>] btrfs_qgroup_free_refroot+0x140/0x170 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff882d9b21>] __btrfs_run_delayed_refs+0x2c1/0x10a0 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff88097513>] ? dequeue_task_fair+0x5b3/0x880 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff8809845e>] ? put_prev_entity+0x2e/0x700 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff880b761f>] ? lock_timer_base.isra.24+0x4f/0x70 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff882dd7dd>] btrfs_run_delayed_refs+0x7d/0x2e0 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff882f34e4>] btrfs_commit_transaction+0x24/0x60 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff882ee056>] transaction_kthread+0x216/0x230 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff882ede40>] ? btrfs_cleanup_transaction+0x4a0/0x4a0 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff88088296>] kthread+0xe6/0x100 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff880881b0>] ? kthread_create_on_node+0x170/0x170 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff88a58a1f>] ret_from_fork+0x3f/0x70 Aug 20 13:29:42 Vierings-Daten kernel: [<ffffffff880881b0>] ? kthread_create_on_node+0x170/0x170 Aug 20 13:29:42 Vierings-Daten kernel: ---[ end trace 54ab9bdf11da690b ]--- Aug 20 13:29:42 Vierings-Daten kernel: BTRFS warning (device md127): qgroup 12508 reserved space underflow, have: 0, to free: 4096
Could do you please enable sceure diagnotic? I need to ask our developter to remote access to fix it.
RAIDar Secure diagnostic
https://kb.netgear.com/27391/ReadyNAS-RAIDar-6-0
or enable secure diagnosticn in NAS admin GUI =>System=>Settings=>Support,
the PM me 5 digital.
- Miraculix1Aug 23, 2017Tutor
Hi Evan,
do you know if some looked at the filesystem error?
The secure diagnostic stopped this night and I activated it again.
I sent the code to the same adress I sent the log files.
- evan2Aug 23, 2017NETGEAR Expert
Get feedback from developter,
The btrfs warning message is neither new nor common, but the message is new. The error has no effect on data safety or anything related to that.
In the next firmware release 6.8.1 you should no longer see this message.
There is a topic to discuss the problem, https://community.netgear.com/t5/Using-your-ReadyNAS/6-8-0-Kernel-warning/m-p/1353378#M135290
I didn't find other problem from your NAS,
Could do you please enable SSH and login NAS via SSH?
then run top command to check the resouce loading when you delete files useing finder
By the way,
Did you install MySql? I see your root paratition (md0) is used 81%, the root paratition is easy to full on your NAS,
You may check ibdata1 size in /var/lib/mysql via SSH login,
below is example,
root@nas-43-97-44:/var/lib/mysql# ls -alh total 2.3G drwx------ 1 mysql mysql 182 Aug 16 01:21 . drwxr-xr-x 1 root root 298 Aug 16 01:17 .. -rw-r--r-- 1 root root 0 Aug 16 01:17 debian-5.5.flag -rw-rw---- 1 mysql mysql 2.3G Aug 16 01:55 ibdata1 -rw-rw---- 1 mysql mysql 5.0M Aug 16 01:55 ib_logfile0 -rw-rw---- 1 mysql mysql 5.0M Aug 16 01:54 ib_logfile1 drwx------ 1 mysql root 2.1K Aug 16 01:18 mysql -rw------- 1 root root 6 Aug 16 01:18 mysql_upgrade_info drwx------ 1 mysql mysql 868 Aug 16 01:18 performance_schema drwx------ 1 mysql mysql 32 Aug 16 01:21 sbtest
ok, thanks.
I am sorry, top shows nothing special to me, when deleting a file.
You are right, mysql is running, I think plex uses it, the size is 18M, is this too large?
