gridding
Nov 14, 2019Aspirant
RN 102 connection via USB & Ethernet
Hi I have an RN 102 with 1 HDD in at present and am connected to in on my network via ethernet , connection running off my laptop at 10 mps. It wasn't a problem this speed untill recently I tho...
- Nov 15, 2019
Sandshark wrote:
Are you sure you are runnig at 10m bits per second, not 10m bytes per sec, which is close to what you'll observe with a 100m bits per sec connection.
That is the first thing to confirm. You can see this in Windows - if you are running Windows 10, the process is here: https://winaero.com/blog/see-the-ethernet-or-wifi-adapter-speed-in-windows-10/
If you are running 10 m bits, then I suggest starting by getting a new ethernet cable between the laptop and the switch. You could also try a new switch port.
FWIW, upgrading your FS605 switch to a gigabit switch would be very inexpensive. A GS308 costs less than $20 on Amazon US at the moment. I'd do that even if your current laptop can't take advantage of it.
You could get a USB 3.0 ethernet adapter for your laptop for another $15 or so. But you need at least a cat5e ethernet cable in order to get gigabit speed. Most cables have that rating printed on the cable itself - if yours doesn't, then maybe add a cat 6 or cat 6a cable to the order.
Doing all three of these things should get you a lot better speeds for less than $50US.
Nov 14, 2019Guru - Experienced User
The USB connectors on the ReadyNAS can only be used for adding a USB drive or a UPS. So it has to be connected to your network over ethernet. You can of course reach it with either wifi or ethernet.
10 mbps is very slow for modern ethernet - most folks would have gigabit, with some others using 100 megabit ethernet.
Can you describe the connection path between the laptop and the router (any switches, hubs, etc)?
If the NAS is near the laptop, then one option is to get a small gigabit switch (~ $20 USD), and connect both the laptop and the NAS to the router using the switch. Then you'd have a gigabit connection to the NAS (though the link to the router would still be slow).
- griddingNov 14, 2019Aspirant
Hi
Thanks for the swift response,
My laptop is a HP pavilion g6 2244 connected via ethernet to a netgear F605 10 / 100 switch
The RN102 is also connected to the same Netgear switch
I was always under the impression the connection speed should be automaticly set, is ther any way of interogating the switch ?
or is it more likeley the drivers for the laptop ?
the network lights are flashing amber ( orange ) when transfering data which I believe to be 10 mps
the transfer speed on the laptop also says 10 mps
any ideas
cheers
Graham
- SandsharkNov 14, 2019Sensei
The network speed is auto-negotiate, up to the max rate of the slowest component involved.
From the specs on your computer: Network Card Integrated 10/100 BASE-T Ethernet LAN
You are the unfortunate victim of a computer company trying to save pennies on a low-end consumer PC. Since most use WiFi on a laptop, there were computers of that era (2012/13) that didn't bother with a gigabit Ethernet connection. Yours is one of them.
Since it has USB3, a USB3 to gigabit Ethernet adapter (assuming your network supports gigabit) or an AC WiFi USB device (assuming your router/access point supports AC protocol) could improve your speed.
- griddingNov 14, 2019AspirantHi
Thanks for those thoughts, if I have an ethernet adaptor in the laptop , a network switch all 10 / 100 spec any ideas why I cant get in the 100 mps bracket, can cables be a contributing factor ?
Cheers
G
