Tom_BSS's avatar
Tom_BSS
RN-102 firmware upgrade failure
If a NAS 10200 chassis is unbootable (upgrade failure), can the disks be removed and installed in another chassis or read in some other way?
  • Tom_BSS's avatar
    Tom_BSS
    Aug 02, 2016
    Thank you for your help. We resorted to paid Netgear Tech phone support which was very helpful. It turns out the upgrade did go through the first time, but the NAS got hung up somehow. All is good now!
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi Tom_BSS,
    Welcome to the community!
    Yes. You can load the disks on a similar chassis but ensure that they run the same Firmware version. If this has been met, the device will load up just fine. Can you confirm what happened to the update and whether it's done automatically (remote) or local upgrade procedure?
    Kind regards,
    BrianL
    NETGEAR Community Team
    • Tom_BSS's avatar
      Tom_BSS
      The RN-102 was purchased with FW 6.0.8 and (in 2014) and I have never done any maintenance on it. Last night while browing through the 'dashboard' or 'control panel' it checked for upgrades and was recommended to upgrade to 6.2.5, which I started. This was from my Windows 7 PC on our small LAN, so I suppose it would be considered a local upgrade. The file(s) downloaded fine but the NAS didn't reboot properly. At some point during the process the Cat 5 cable from the router was momentarily unplugged (I was tired and doing too many things at once). The message came up that the upgrade failed, to NOT reboot and call tech support. At this point both drive lights are on steady and the power light is blinking. I have downloaded the USB Recovery tool and plan to try that process, but am now being slow and careful.
      Thank you for your quick replies.
      You guys are great.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Does the NAS show in RAIDar?
    Have you tried powering off the system and powering it on again to see what happens?
    Have you tried a cold boot (shutdown, unplug power for say 5-10 minutes and then plug power back in)?
    Are you still able to access the boot menu?: http://kb.netgear.com/app/answers/detail/a_id/22892/~/how-do-i-access-the-boot-menu-on-my-readynas-102,-202,-212-or-312%3F
    Local/remote upgrade should make no difference. Getting prompted for a remote upgrade would just indicate that the NAS has a working internet connection. Either way the integrity of the downloaded image is verified before the update is installed.
    Note if the problem is on the disks and not with the chassis then it will remain when moving it to another chassis.
    Also you don't have to move to another RN102. You could move to e.g. a RN212 if you prefer.
    • Tom_BSS's avatar
      Tom_BSS
      The recommended upgrade for this unit, and what I attempted, was to 6.2.5. The USB Recovery tool instructions and links say to use ARM, which is 6.5.1. Should I proceed with the 6.2.5, then maybe take another jump to 6.5.1 later?
      • StephenB's avatar
        I would.  There are some warnings about jumping from very old firmware directly to 6.4 and 6.5.
ProSupport for Business
