6ril
Dec 20, 2014Aspirant
RN 104 poor performance -> unusable
Hi, I have a RN 104 with 3 2TB disks in RAID5. The performance I'm talking about is simply FOLDER ACCESS!! some folders can be accessed normaly, and others are just unbearable slow, like 7 minu...
vandermerwe
Dec 20, 2014Master
What firmware are you running?
What disks ( make and model) are you using? Are the disks' smart stats OK?
How you you accessing the nas? From a windows PC? How is the PC connected to the LAN and how is the NAS connected to the LAN?
So you have any apps installed? I see from some of your previous posts that you had transmission/torrent apps installed. Is that on this device?
Do you have antivirus enabled?
Do you have continuous protection enabled on any shares, particularly transmission shares?
Do you have COW enabled on any shares?
Have you always had this problem or is it a new problem?
How much space is free in the volume?
