6ril
Dec 20, 2014Aspirant
RN 104 poor performance -> unusable
Hi, I have a RN 104 with 3 2TB disks in RAID5. The performance I'm talking about is simply FOLDER ACCESS!! some folders can be accessed normaly, and others are just unbearable slow, like 7 minu...
6ril
What firmware are you running?
6.2
What disks ( make and model) are you using? Are the disks' smart stats OK?
WD red 2Tb x3
How you you accessing the nas? From a windows PC? How is the PC connected to the LAN and how is the NAS connected to the LAN?
win7 x64 pc ->switch->NAS 2 pc actually, everything is going through gigabit switch
So you have any apps installed? I see from some of your previous posts that you had transmission/torrent apps installed. Is that on this device?
only app I use is Qbitorrent.
Do you have antivirus enabled?
It was untill 1 hour ago, I disabled it and it seems (NOT SURE AT ALL) to have improved access, but I never know since this pb sometimes stops by itself after a few painful connections...
Do you have continuous protection enabled on any shares, particularly transmission shares?
No
Do you have COW enabled on any shares?
COW??? don't know what your talking about, and i'm in the countryside.
Have you always had this problem or is it a new problem?
not new, i'd say almost since the start.
How much space is free in the volume?
1.94TB free of 3.56TB
thanks for your concern :) I hope you can help?
6.2
WD red 2Tb x3
No
